SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
April 24, 2021 * 22 posts * 237 views
ttocs said: its the bushings in them that are known to wear out and that could allow movement of the rear end. Sometimes you can get under the car and see if they are bad otherwise its a matter ... Read more >>
April 24, 2021 * 8 posts * 159 views
Paladin1001 said: Sounds to me like the pilot bearing is bad. My daughter's 98 GT was exactly like that when I bought it. The clutch held fine, it had been replaced but they didn't put a new pilot ... Read more >>
April 24, 2021 * 4 posts * 75 views
JoeR40065 said: I know that I'm not boosted or anyting but I am or I did just go through the exact same issue come to find out my vacuum line to iac valve tied iinto both pcv valves?? However ... Read more >>
April 24, 2021 * 6 posts * 141 views
Procharged87 said: Your numbers look pretty good. You may have a few more ponies on the table but, if you're bottom end is stock, I wouldn't push it much harder, especially with the hypereutectic ... Read more >>
April 24, 2021 * 2 posts * 68 views
07GtS197 said: I have an old x3 but it's locked, I doubt you'd want it but thought I'd throw that out there. Sent from my iPhone using Tapatalk Read more >>
April 25, 2021 * 1 post * 4 views
SN95Newsletter said: Click here to view on the web Highlighted posts Strange sound from gearbox April 24, 2021 * 16 posts * 157 views 96-04 - 2V Specific Mail order tunes April 23, 2021 * 9 posts * ... Read more >>
April 24, 2021 * 31 posts * 1,189 views
JoeR40065 said: I cannot recall if I got a message please try again , also can contyme via Facebook messenger [email protected] but don't email that box it's unmonitored Read more >>
April 25, 2021 * 54 posts * 1,219 views
Daryl said: Gents, Simmer down! Sim. Merrrr... I put 260 miles on today, so I'm WELL OVER the 750 mile requirement. I'm dropping the car off Wednesday morning. They're going to do a cold start, ... Read more >>
Continue reading...
