Highlighted posts from Sunday, Nov. 14, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
November 10, 2021 * 23 posts * 179 views
07GtS197 said: I don't recommend that arrangement because the coolant temp will be wrong until the thermostat opens. Maybe it won't make much of a difference, I've never tried it. I was going ... Read more >>
November 13, 2021 * 15 posts * 138 views
OpalFrostGT said: Please remember that I have a dry sense of humor. Instead of investing everones time and effort, I suggest Itsell (original poster) go back to the parking lot where the photo was ... Read more >>
November 14, 2021 * 7 posts * 57 views
ttocs said: you have multiple problems going on. For example the flashing overdrive light means that a trouble code has been found and stored. I would check to see what that code is and it ... Read more >>
November 11, 2021 * 23 posts * 291 views
ttocs said: It could be an exhaust leak when its hot or you can try swapping O2s and see if it moves or a new one and see if it goes away. Read more >>
November 10, 2021 * 28 posts * 297 views
Notthenow said: Make sense, at least in what I saw. Good to know. In the past (look at me talking as if 2v 4.6 tech is new) it didn't matter as much because the gasket material and sealer could ... Read more >>
November 10, 2021 * 7 posts * 60 views
Chenn2389 said: I bought it from a guy that was too cheap to tune his ported GT40p set up with TFS-1 cam. Instead he had adjustable fuel pressure regulator with the pressure bumped up and timing ... Read more >>
November 12, 2021 * 1 post * 12 views
SN95Newsletter said: Click here to view on the web Highlighted posts Heater crossover pipe November 11, 2021 * 23 posts * 136 views 94-95 5.0 - Specific Intake option for PI head swap November 11, ... Read more >>
November 13, 2021 * 39 posts * 498 views
96blak54 said: Hey brother,....dreams is where we all started. Dont let obstacles get in the way. Work hard, long hours. Save your money and get to wrenching.....youll figure it out and we'll ... Read more >>
November 12, 2021 * 14 posts * 311 views
Daryl said: That's "a do-over"! Sorry it didn't pan out for you. You know you'll never be happy with it, so I say scrap it and get a proper kit or have a muffler shop run it back from the ... Read more >>
Continue reading...
wbarter
