Highlighted posts from Sunday, Oct. 24, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
October 24, 2021 * 37 posts * 236 views
TrickVert said: Shorties can show some slight low-end torque gains, and a small amount of HP, but the general consensus is that they're not worth the cost or hassle. They look nice and change ... Read more >>
October 23, 2021 * 7 posts * 55 views
ttocs said: seriously if you paid for it you should have either turned around on the way home or called and told them what it was doing. Did they replace the entire assembly or just the gears? Read more >>
October 23, 2021 * 7 posts * 53 views
TrickVert said: ... And look better than the 2.25" stockers. It's surprising how much of a difference just that additional 1/4" in diameter makes. Read more >>
October 24, 2021 * 6 posts * 35 views
TrickVert said: You just answered your own question, then. Aftermarket head unit with a CD/DVD player. Many people have fit double-DIN units if you're so inclined. I opted for a single-DIN Kenwood ... Read more >>
October 24, 2021 * 2 posts * 10 views
mstinaff said: I managed to pull a 4.10 gear limited slip rear end from an explorer sport trac at the local wrecker. I don't have room to store the whole rear end right now and would like to ... Read more >>
October 24, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Off-Road H or X Pipes, Where to find them????? October 22, 2021 * 29 posts * 165 views 94-95 5.0 - Specific 97-98 Tailpipes original ... Read more >>
October 23, 2021 * 12 posts * 135 views
tmwsccsh said: I've got those bump things on mine - 1994 Vert. They are peeling loose slightly at the ends - not sure of the best way to stick them back as I don't want the messy goo left on ... Read more >>
October 23, 2021 * 8 posts * 63 views
white95 said: Session 3 [link] Session 3 Black Flagged [link] Session 3 restart [link] Fin [link] Read more >>
October 23, 2021 * 41 posts * 609 views
J_lope82 said: I was looking for royal purple but I could not find it at autozone and oreillys so I went with Valvoline. That was what oreillys had. Autozone only had two quarts of pennzoil. ... Read more >>
Continue reading...
jdude138
