Highlighted posts from Tuesday, Aug. 09, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
August 08, 2022 * 29 posts * 306 views
JPuehl said: Seems like a lot of responses to say that problem may be the shifter, lol. I did order a tri-ax btw to try. Read more >>
August 08, 2022 * 11 posts * 85 views
Full_Send said: I figured it out had a friend hook up hp tuners and discovered the previous had a tune in the car with really high fan engagement points and that despite my temp gauge functioning ... Read more >>
August 08, 2022 * 4 posts * 21 views
dwcopple said: Do those clusters automatically adjust for rear end gear swaps? Reason, I ask, I have a 2000 GT supposedly swapped to 4.10s. The speedo is correct right now, however, the car has ... Read more >>
August 08, 2022 * 4 posts * 53 views
Monday said: Have you given the wheels a pull when it is off the ground? Have you new wheels bearings? Double check wheel bearing torque; should be at or around 155 ft/lbs. Do you know where ... Read more >>
August 08, 2022 * 3 posts * 27 views
Venompower said: Just wanted to throw this out for anyone considering purchasing car audio... if you saw my recent thread you would know that my order arrived missing the Metra harness adaptor ... Read more >>
August 09, 2022 * 2 posts * 14 views
92wastheyear said: Ok....so this is kinda lame, but I bought one of those cueball type Hurst shift knobs from Amazon (had gift card) for my '96 vert w/ stock 5-speed. All the references say that ... Read more >>
August 08, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Notchy shifting August 07, 2022 * 27 posts * 253 views Drivetrain Tail Pipe Question August 08, 2022 * 19 posts * 122 views Exhausts ... Read more >>
Continue reading...
TN95gt
