SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
December 27, 2021 * 8 posts * 56 views
Randall Garner said: Verify plug wire installed correctly also. #1 tdc verify rotor lines up near #1 if you know cam manufacturer and a part number . You could go to that manufacturer web site to verify ... Read more >>
December 28, 2021 * 61 posts * 564 views
Gregomatic said: So do you think the Duralast was not in a fully charged state when you first installed it? Or that it failed at some point in your testing? Something isn't computing but I can't ... Read more >>
December 27, 2021 * 5 posts * 68 views
MTRHDROB said: A good diff will help you put the power down coming out of the turn. understeer is a problem with the front setup. Read more >>
December 27, 2021 * 2 posts * 26 views
CobRyan said: What suspension bushings are recommended to improve handling and which brand do you recommend? Is there a "package" that includes them all? Thanks Read more >>
December 27, 2021 * 5 posts * 64 views
ttocs said: yea with that book you should be answering questions, not asking. I have the 94 version here that I brought up yesterday to check out trans wiring. Read more >>
December 27, 2021 * 4 posts * 74 views
joemomma said: Nah just a street car. No inspections in my neck of the woods. Read more >>
December 28, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Engine shuts down when o cap is off December 26, 2021 * 2 posts * 17 views 94-95 5.0 - Specific Need firing order for an unknown ... Read more >>
December 27, 2021 * 51 posts * 600 views
ttocs said: if I had to do another I could do a crab claw. Read more >>
Continue reading...
