Highlighted posts from Tuesday, Jun. 21, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
June 20, 2022 * 16 posts * 156 views
Wmac said: If you are planning upgrades to 350hp, then "beefing-up" the rear end is a good idea. 3.73 gears are just the ticket for any 4R70W trans. If you have any plans for drag radials, ... Read more >>
June 20, 2022 * 10 posts * 51 views
Stangswagalicious said: Well, my plan is to start at the actuator and see if its getting power when i hit the switch. Il probably be doing that today. However, i will definitely start at the passenger ... Read more >>
June 20, 2022 * 5 posts * 49 views
cobrajeff96 said: Make sure the grounds on the temp sensor(s) are not corroded, which is usually just the threads of the sensor itself. Hook up a scan tool (either rent one or buy a cheapo one at ... Read more >>
June 20, 2022 * 9 posts * 100 views
cobrajeff96 said: Oh ok, I thought you mean like it runs for a good while after power is removed. What you're describing is normal operation though. If you're concerned about the system maintaining ... Read more >>
June 21, 2022 * 2 posts * 13 views
jmmorgan4 said: just need some help figuring out the wiring for the 5.0L cooling. i know lo fan wire is the middle and hi fan is the outside wire. when i test voltages the low fan wire says 12v ... Read more >>
June 21, 2022 * 1 post * 14 views
Musturd said: Vortech v3 sci kit C&l inlet tube Anderson power pipe Turbo smart bov Lightning 90mm maf Coolant crossover pipe $ 2800 [image] Comes complete with all hardware brackets etc . The ... Read more >>
June 21, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts 8.8 rebuild June 19, 2022 * 9 posts * 62 views Drivetrain Trans Holding Fixture June 19, 2022 * 8 posts * 26 views Drivetrain Door ... Read more >>
June 20, 2022 * 9 posts * 183 views
thaliabobalia said: Do any of you think this could be the beginning sign of an oil pump going out? I read on another forum (corral.net) of a guy having the same problem as me and a few people responded ... Read more >>
June 20, 2022 * 34 posts * 668 views
Venompower said: Update: I actually think the noise is coming from the rear spring upper and lower insulators. I think a combination of old damaged insulators and not being seated well on the control ... Read more >>
Continue reading...
marktuck99
