SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
June 21, 2021 * 8 posts * 46 views
Daryl said: Just wondering if there are options/upgrades to the stock power steering rig? I'm ok with it, but I'm just curious??? Read more >>
June 19, 2021 * 19 posts * 148 views
Chenn2389 said: The switch and pigtail I soldered in is removed and all the wires are isolated. Right now, I have used my multimeter and tested the light blue with red strip wire at every location ... Read more >>
June 18, 2021 * 16 posts * 218 views
96blak54 said: Any thumping cam will do just that with the right gearing. Read more >>
June 19, 2021 * 4 posts * 40 views
Flade said: The part it holds is the Brake Pedal Switch Vacuum Cruise Control Cancel Sensor not sure what the mount is called, but since you haven't told us what year car or engine we are ... Read more >>
June 22, 2021 * 3 posts * 11 views
96blak54 said: Here is my latest escapade. For the last 5ish years. Ive been tinkering around building a camshaft grinder, mostly centered around grinding modular ford cams, but does accept any ... Read more >>
June 20, 2021 * 8 posts * 171 views
RAU03MACH said: When I put the supercharger on my cobra And tore the engine this last round apart the top end had quite a bit of residue of oil I can tell that a supercharger dose suck more oil ... Read more >>
June 21, 2021 * 7 posts * 102 views
joemomma said: Looked things over more closely this weekend (Saturday morning before I washed it). It definitely seems to be the tensioner pulley. Read more >>
June 21, 2021 * 1 post * 12 views
SN95Newsletter said: Click here to view on the web Highlighted posts Dash lights stay on, dimmer switch dimming parking/running lights. June 19, 2021 * 19 posts * 103 views Electrical & Stereo Learning ... Read more >>
June 19, 2021 * 42 posts * 575 views
Chenn2389 said: Is there a way to remove the section about electrical issues?! I made a separate thread for that and found/fixed the issue. Read more >>
Continue reading...
