SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
March 21, 2022 * 59 posts * 503 views
Tim300wsm said: I will be the first to admit that I am completely new with fords and know fuck all about them. Having said that I've played with and worked on cars for quite some time. In that ... Read more >>
March 22, 2022 * 11 posts * 110 views
Gregomatic said: A kit similar to this is what I'd really like. But it has no spider gears! Do the not make kits with ring, pinion and spider gears? [image] JEGS 60007KPart Number: 555-60007K GM ... Read more >>
March 21, 2022 * 13 posts * 110 views
Makoto said: the washers on each side have tabs that fill in the void to prevent the bolt from walking back. similar to the one below but this is before i added more material and made the shoulders ... Read more >>
March 21, 2022 * 4 posts * 24 views
Monday said: I have new pulleys (all) and now have a tensioner (also new) alignment problem. Has any of you ever added a shim or two to your belt tensioner to bring to where it rides aligned? ... Read more >>
March 21, 2022 * 1 post * 24 views
Daryl said: I'm reversing... no, "amending" my earlier decision to get away from the blacked out look. A while back I put in a "contact me when it's back in stock" ticker with LMR regarding ... Read more >>
March 21, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Engine swap planning - analysis paralysis March 20, 2022 * 53 posts * 430 views Engine Swap Ford tolerances suck (IRS perfection ... Read more >>
March 21, 2022 * 51 posts * 339 views
Carl The Cobra said: Ok I will test this if the multifunction switch doesn't fix it. Read more >>
March 21, 2022 * 11 posts * 154 views
Duff said: Update on spring install. Yes, you do need an internal style spring compressor to install stock height springs in a 95. Everything went well, except I didn't check the new struts ... Read more >>
Continue reading...
