Highlighted posts from Tuesday, May. 10, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
May 09, 2022 * 12 posts * 54 views
joemomma said: In light of the recent hood fly up that was posted, it got me thinking about Aerocatch latches since i run an aftermarket fiberglass hood. I know a bunch of you guys run them...looking ... Read more >>
May 09, 2022 * 16 posts * 98 views
Stangswagalicious said: Excellent. I may just do that. To me it seems like whatever it is causing this is related to the voltage regulator. If the field isnt getting power, then that explains a lot. Especially ... Read more >>
May 09, 2022 * 24 posts * 248 views
Buffalo5Spd said: Try like thee weeks lol. Then quit again because the job's too hard (33yrs old). Most of the other drivers we have are over 50. A couple are over 60. Many of these kids are just ... Read more >>
May 09, 2022 * 10 posts * 76 views
Jakespeeds said: I have had the BBK units on my car for 6 years at least. The car for 5 years was almost only used for autocross days. Never had an issue with them. They have never loosened. My ... Read more >>
May 10, 2022 * 4 posts * 22 views
ProMach1 said: Ok guys, quick question. I recently replaced the plugs in my 03 Mach one and all of a sudden I am throwing 2 codes. P0330 and P1151. I switched from NGK TR6 Iridiums to TR6 Copper ... Read more >>
May 09, 2022 * 5 posts * 37 views
white95 said: The module should be inside the LH, rear quarter panel behind the trunk interior trim. Read more >>
May 09, 2022 * 4 posts * 28 views
Daryl said: Reservoir and radiator levels are bang on balls accurate. Coolant low light comes on... and as you can tell by the Temperature gauge, I just started out on an errand. Wut the???? ... Read more >>
May 10, 2022 * 2 posts * 14 views
Biggredd said: Hey guys This is a new one for me. Rough chain of events. First, car died on test drive after getting out of storage. Pump priming with no fuel to tail, turned out the fuel pump ... Read more >>
May 09, 2022 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts Kenny Brown caster plus CC plates May 08, 2022 * 14 posts * 90 views Suspension and Brakes Temperature sensitive charging issue?? ... Read more >>
Continue reading...
marktuck99
