Highlighted posts from Tuesday, Nov. 09, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
November 08, 2021 * 18 posts * 120 views
Michael Plummer said: FYI Your camshaft profile will have the biggest effect on idle quality, while spark advance, A/F ratio, and your processor's ability to chase a desired idle speed thru spark advance ... Read more >>
November 08, 2021 * 69 posts * 550 views
lwarrior1016 said: He did that, that's why it's high now. He gave it more air through the throttle blade and the iac is letting even more air in on top of that. When the iac duty cycle gets lowered, ... Read more >>
November 09, 2021 * 9 posts * 76 views
Daryl said: Actually, no! The jack, bolt and nut are the same, but the tire in your photo is upside down compared to the video I saw. Mine then requires a "cup"(basically a really large washer) ... Read more >>
November 08, 2021 * 6 posts * 32 views
RacerX said: Just picked up an Accufab upper plenum/TB combo and have all the toque specs except the 5 bolts that mate the upper plenum to the lower intake manifold. Does anyone have a number ... Read more >>
November 09, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Car is tuned, runs great, at idle it dies when all the electronics are on November 08, 2021 * 68 posts * 482 views 96-04 - 4V Specific ... Read more >>
November 09, 2021 * 49 posts * 397 views
Gregomatic said: I don't blame you a bit there brother! Hey, I think that grease finally worked its way in because it's a little quieter! But by pressing about 5 lbs of pressure on the clutch, ... Read more >>
November 08, 2021 * 16 posts * 214 views
Paladin1001 said: Nothing wrong with either car, its pretty cool to buck the popularity trends. I think the SN's are highly under rated, and our car choices don't have to please anyone but us, right? ... Read more >>
November 09, 2021 * 8 posts * 135 views
Gregomatic said: Delling, I love, love, love projector LED's and wanted a set so bad after I had a 12 point Whitetail buck destroy my front clip. But I did a LOT of research and talked to many ... Read more >>
Continue reading...
wbarter
