SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
November 29, 2021 * 35 posts * 308 views
joemomma said: My local shop charged me something like $100 to mount/balance tires and wheels that I brought in. It may have even been slightly more than that - I'm thinking like $125? I don't ... Read more >>
November 29, 2021 * 2 posts * 20 views
kcraidersfan816 said: So i have a little issue my pos doesn't like to run right unless my timing is super advanced it is currently set at 21 deg adv harmonic balancer is dead on since i just put new ... Read more >>
November 29, 2021 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Timing November 27, 2021 * 62 posts * 384 views 94-95 5.0 - Specific Staggered Rims/Tires........... November 29, 2021 * 24 posts ... Read more >>
November 30, 2021 * 22 posts * 230 views
Gregomatic said: "Too bad the exhaust is grounded. An ignition coil wired up to it would be fun." Ya know, I think Trick is onto something here. So, they're gonna be wearing gloves, but wouldn't ... Read more >>
November 30, 2021 * 11 posts * 103 views
ttocs said: most fans will only have 2 wires. That doesn't necessarily mean its a one speed fan unless its only hooked up to a car like ours that uses 2 wires to control speed. I have not ... Read more >>
November 29, 2021 * 7 posts * 241 views
J_lope82 said: I'll double check to see what the switch is for but I think it was for a sound system that is no longer there. Right now I flip the switch back and forth and it doesn't do anything. Read more >>
November 30, 2021 * 16 posts * 355 views
ttocs said: if your using the power bleeder I found if I pinched the hose a little on/off while holding down the trigger it helped to build just a little more pressure and helped to get a ... Read more >>
Continue reading...
