SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
April 19, 2022 * 25 posts * 236 views
Makoto said: what i did i was get the STB for the engine that was in the car. so its effectively a 99 which meant i needed a 99+ cobra STB. i had to eliminate the arms going back because of ... Read more >>
April 19, 2022 * 8 posts * 42 views
Daryl said: Yes, probably only 10% freeway. And here in CA, at $5.70/gal for gas, I'm in no hurry to burn through my fuel so I don't drive it too hard. Well ok, maybe every once in a great ... Read more >>
April 19, 2022 * 12 posts * 137 views
badass98svt said: I have had sequential on my 98 since 2004, and before that I had them on my 97. I've always liked the look, and the throw back to the old Shelbys. There is a write up somewhere ... Read more >>
April 19, 2022 * 23 posts * 241 views
badass98svt said: I forgot about that little bugger in there. I need to pull the radio anyway, as there's just not enough real estate back there for the double DIN radio to sit in all the way. I ... Read more >>
April 19, 2022 * 4 posts * 29 views
Daryl said: Why do I feel like this should be a straight forward, easy job? All I'm trying to do is disconnect the upper part of the front brake line. I put a 15mm on one side and a box end ... Read more >>
April 19, 2022 * 3 posts * 17 views
DMG said: 94 GT/5mt with GT40P stuff. I have BBK long tubes that burn plug wires, even custom wires with Kevlar shields. Now I need to do a compression test and can't do that without pulling ... Read more >>
April 20, 2022 * 32 posts * 392 views
RacerX said: The real clog is the plenum so changing the throttle body won't change much but you will notice a bump from just the new plenum. Two ways you could go about it, get just the plenum ... Read more >>
April 19, 2022 * 15 posts * 168 views
badass98svt said: 1 question: Was the vibration there before you changed the trans? If it's a new vibration, then you probably need to unbolt and rotate the driveshaft a quarter or half turn then ... Read more >>
April 19, 2022 * 3 posts * 26 views
cryptospook said: [image] So is this a legitimately bad O2 sensor cause it's not voltage switching at idle? Read more >>
April 19, 2022 * 33 posts * 440 views
badass98svt said: Any bodyshop or paint supply place in your area can get you the SEM. I've ordered it on Amazon before too. (not Ultra Trim Black, just ask for Trim Black). SEM is professional ... Read more >>
Continue reading...
