Highlighted posts from Wednesday, Aug. 18, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
August 17, 2021 * 23 posts * 166 views
Monday said: One's a tensioner; other's an idler. I've changed both. No squeeks. You can always spray a little Silicone Lubricant around the back of both, into the bearings if you can - use ... Read more >>
August 17, 2021 * 15 posts * 102 views
joemomma said: You could probably use something like plexiglass or acrylic if weight is an issue, although to get a rigid "plastic" you'd need to go fairly thick, and that stuff gets heavy quickly. ... Read more >>
August 17, 2021 * 12 posts * 72 views
Project Grey94 said: Thank you sir I have done that this morning and it showing that I am a tooth off number one on top of the distributor so I remove the distributor and moved it a tooth to where ... Read more >>
August 17, 2021 * 5 posts * 53 views
white95 said: Everyone post their favorite picture of their SN95! Anything goes this round. Nomination period will end August 30th. The winner will receive this t-shirt: [image] Depending on ... Read more >>
August 17, 2021 * 1 post * 13 views
evil2vgt said: I just had my 2.1 rebuilt and purchased a 2.6 mammoth inlet from Kenne Bell at the same time. I also had them install a spacer for fuel rail clearance. The issue I am having is ... Read more >>
August 18, 2021 * 1 post * 5 views
SN95Newsletter said: Click here to view on the web Highlighted posts Rear seat delete August 16, 2021 * 12 posts * 42 views Exterior and Interior Squeaky, squeally sound?? August 16, 2021 * 19 posts ... Read more >>
August 17, 2021 * 30 posts * 314 views
Venompower said: Looks @TrickVert posted in a thread earlier this year that he had a hole in the rubber s-hose at the fuel pump that only caused pressure issues at higher rpm. This may be the problem ... Read more >>
Continue reading...
