SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
August 24, 2021 * 17 posts * 100 views
Adfalenski said: The difficulty with checking a speedometer cable is getting to the end that connects to the speedometer. The speedometer cable is a long flexible cable that is inside a long flexible ... Read more >>
August 24, 2021 * 15 posts * 55 views
tvsn95 said: My set up uses an HP turbo setup ( no longer available) I have also done the On3 in a fox,, There is little diff in install per car but the turbo is turned 90 degrees and sucks ... Read more >>
August 24, 2021 * 12 posts * 47 views
Daryl said: Noticed this little bit of fraying left side of belt. Does this need replacing or is it ok? Also wondering if it's contributing to the "squeaky, squealing" noise I'm getting (refer ... Read more >>
August 24, 2021 * 8 posts * 36 views
Daryl said: So I decided on the PA Performance high torque mini starter. I'm a bit confused as to the wiring. Here's a pic or two of my set up: [image] Read more >>
August 24, 2021 * 5 posts * 20 views
Horus Works said: I've got some free play in my rear wheels, when I push on them from side to side. Looking closely I can see that my cross axis joints are shot! Any tips for swapping these out ... Read more >>
August 24, 2021 * 4 posts * 47 views
lwarrior1016 said: Man, I really think you need another transmission. These transmissions are really bad about breaking to snapping off the forward drum. If it happens just right, it could lock the ... Read more >>
August 24, 2021 * 6 posts * 95 views
07GtS197 said: If adjusting the rack doesn't work I'd look at the steering pump. It almost sounds like you have too much assist. Read more >>
August 24, 2021 * 2 posts * 21 views
J_lope82 said: 96 mustang gt with original 5 speed manual trans. It does have a after market clutch and a aftermarket shifter. It has original cable and quadrant. The problem is I usually have ... Read more >>
August 24, 2021 * 7 posts * 136 views
BOTTLEFED5 said: I cannot take credit for taking this picture of my ride but its one of my favorites [image] Read more >>
August 24, 2021 * 1 post * 15 views
Venompower said: If anyone is running a slot style MAF, or running the VMP 5000 slot style MAF... I was hoping you could post a picture of the actual sensor. My VMP 5000 is pegging to 1023 at WOT ... Read more >>
Continue reading...
