Highlighted posts from Wednesday, Jul. 06, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
July 05, 2022 * 9 posts * 47 views
MyLittlePony said: I had this problem back when my car was a stock v6. I didn't know if it was the factory wheels, or the hood, or the convertible top. The suspension was factory, but 8yo. With wider ... Read more >>
July 06, 2022 * 5 posts * 32 views
SN95_Project said: So I THINK I found the receptacle for thr passenger side. See the attached pic. I also went crazy with degreaser and cleaned up the rack. It's gonna have to come off anyway so ... Read more >>
July 06, 2022 * 1 post * 0 views
Sn95 matt said: i have a 1994 gt convertible and i need help with it little over a year ago when i bought it, it ran fine besides over heating issue i fixed the overheating issue and dove into ... Read more >>
July 05, 2022 * 10 posts * 188 views
joemomma said: I'll be pulling the isolators out once I have my tools and stuff at the new house. They're currently buried somewhere in our storage rental. Read more >>
July 05, 2022 * 7 posts * 107 views
ttocs said: if you go to the fastener section of autozone they have a half a dozen different types of those plastic push pins to choose from. Finding the right one for the hole can be hard ... Read more >>
July 05, 2022 * 2 posts * 47 views
delling3 said: Yes they are aftermarket. IIRC they are Powerstop brand. I purchased these from ROCK Auto over a year ago, and I cannot locate the receipt to confirm the brand. There is no manufacturers ... Read more >>
July 05, 2022 * 2 posts * 27 views
dalpoas83 said: I would think that would clear fine but look around in here for the old threads on here to be sure or maybe someone else can chime in. I've had 315/35/17 on the rear with no rubbing ... Read more >>
July 05, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Drifty, floaty sensation at speed July 04, 2022 * 13 posts * 136 views 94-95 5.0 - Specific Cruise Control Fix for LED Tail Light ... Read more >>
July 05, 2022 * 8 posts * 158 views
cobrajeff96 said: Problem with brake clean is that it leaves a residue behind. Acetone would be better, but then you'd have to apply it with a foam Qtip and extremely gently at that. Best bet is ... Read more >>
July 05, 2022 * 76 posts * 2,062 views
ttocs said: yes the fan has 2 speeds, and the 3 wires control it. One wire for low speed, one wire for high speed and one wire for ground. I am not sure why you are just throwing power on ... Read more >>
Continue reading...
SanMark13
