SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
July 19, 2022 * 24 posts * 180 views
Exhausts
Wmac said: Tail pipe hangars are in a different location on new edge cars (99-04), plus they have 2 hangars on the muffler. Flow tubes may be longer, but they are adjustable. I have a stock ... Read more >>
July 19, 2022 * 13 posts * 61 views
TTSaleen said: As you indicated, your low side pressure is under the required minimum for R134a. As suggested, you need to ensure you put the proper amount of freon in the car (34 ounces) and ... Read more >>
July 19, 2022 * 6 posts * 103 views
i86hotdogs said: I'd find the least expensive kit with a lifetime warranty. Just replaced the clutch on my '98 GT last weekend with a Duralast kit from autozone. Came with the clutchplate, pressure ... Read more >>
July 19, 2022 * 24 posts * 230 views
cobrajeff96 said: Ok, same as mine. Although I wound up using a different FW screw that is much thicker. Probably nothing worth pondering over then. I did however ditch the single hook and got myself ... Read more >>
July 19, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Need to replace part of exhaust.... hard to find OEM July 19, 2022 * 22 posts * 130 views Exhausts MACH 460 with aftermarket head ... Read more >>
Continue reading...
