SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
June 01, 2021 * 4 posts * 117 views
TrickVert said: There are a number of online calculators. Just search for fuel injector size for horsepower calculator, or words to that effect. You will be surprised at the numbers you get. Most ... Read more >>
June 02, 2021 * 4 posts * 35 views
samsonhusky said: So I narrowed it down to fuse 5 and fuse 8 both were putting a drain on the battery. Is there any common problems from anything on these two fuses I need to look into for the drain. ... Read more >>
June 01, 2021 * 7 posts * 241 views
joemomma said: Makes sense - the OBD-I, while simple, isn't all that smart. It can't handle the change in profile outside of one of the mild "letter cams". I'd certainly want a tune once I went ... Read more >>
June 01, 2021 * 1 post * 25 views
Chenn2389 said: [image] I got my engine broke in and changed out the break in oil. Started to rev it higher and give it some throttle. I'm starting to get vibrations 3k rpms plus. The exhaust ... Read more >>
June 01, 2021 * 1 post * 18 views
Burninrock24 said: Is there an alternator relocation kit that allows you to retain air conditioning? I am only finding the MMR kit that goes in place of the A/C unit. No specific motor, just planning ... Read more >>
June 01, 2021 * 19 posts * 361 views
joemomma said: Most of the time it shifts "OK" - not butter smooth by any means. It doesn't grind, but it's certainly not what I would call smooth. Read more >>
June 01, 2021 * 1 post * 4 views
SN95Newsletter said: Click here to view on the web Highlighted posts Fuel pump requirements May 31, 2021 * 2 posts * 27 views 94-95 5.0 - Specific Battery selection... May 31, 2021 * 16 posts * 226 ... Read more >>
June 01, 2021 * 18 posts * 255 views
joe65 said: ive had really good luck with I know i know, Oreily batteries. I have a couple that ive used as extra batteries and i've killed them multiple times recharged and they still work ... Read more >>
Continue reading...
