Highlighted posts from Wednesday, Sep. 14, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
September 13, 2022 * 31 posts * 208 views
dwcopple said: I ordered the purple spring off ebay for $10. I also ordered new solenoids, new circuit board wiring, new filter with gasket, new Dorman pan with drain plug, new accumulator piston, ... Read more >>
September 13, 2022 * 15 posts * 141 views
TTSaleen said: Your plugs are really rich. Have you had it dyno tuned and if so, what was the air/fuel ratio not only during the pull (wide open throttle) but at driveability/cruising? To me ... Read more >>
September 14, 2022 * 9 posts * 45 views
Sn95 matt said: I have a stock 94 gt rn in the next few weeks i plan on put gt40 heads and trickflow intake will i need a tune for this stuff for it to run properly? Read more >>
September 13, 2022 * 4 posts * 26 views
Venompower said: So my car has the VMP blow through setup with the solder in harness/connector for the slot style MAF. I've wanted to move my IAT sensor to post compressor for awhile for safety ... Read more >>
September 13, 2022 * 8 posts * 106 views
Musturd said: Getting your hands on a Anderson cam right now is damn near impossible . Talking with Donny last week I think he had a couple b31's left and that was it Read more >>
September 14, 2022 * 5 posts * 76 views
Snorky said: [image] You can get half of it right here from mustang reaper on Facebook. Imo even this is a bit much. At least it's cheaper than brand new. I don't think you really need them ... Read more >>
September 13, 2022 * 4 posts * 49 views
That Mustang Guy said: Yeah, I know it took me a little bit to get used to it. The only reason I got the 4-inch is because of my intake set-up. Probably could get away with a 3-inch but got this one ... Read more >>
September 13, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts This $#!+box, now P1740 code, trans solenoid? September 12, 2022 * 30 posts * 167 views Drivetrain "Air Bag" light came on yesterday.............. ... Read more >>
September 14, 2022 * 19 posts * 329 views
joe65 said: The guys that are responding here know their stuff keep asking them questions. I vote for the bmr k member also. I just put one on my 4.6 2v and really like it. The stock k member ... Read more >>
September 13, 2022 * 12 posts * 313 views
Monday said: - Remove bottom seat; needs a screwdriver - slotted. - Remove upper back seat - 10mm I believe is the size for your bolts. Mine were stripped so I use over-sized self-tapping 12mm. ... Read more >>
Continue reading...
happliye
