Highlighted posts from Wednesday, Sep. 29, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
September 28, 2021 * 19 posts * 60 views
ttocs said: don't go as far as unplugging at first, just try tapping on them with the back of a screwdriver and then grab and wiggle/jiggle/pull on each harness and see if it studders at all. ... Read more >>
September 28, 2021 * 14 posts * 82 views
Addermk2 said: I have the OEM cluster from my Cobra. I will never be using it again. All of the gauges worked before I pulled it to replace it with a full digital dash. Read more >>
September 28, 2021 * 4 posts * 34 views
Daryl said: What are these? And should they be snugged down all the way? Thanks!! [image] Read more >>
September 28, 2021 * 15 posts * 177 views
ttocs said: Is that a city or monument valley in the background? Nice touch Read more >>
September 28, 2021 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts t56 questions September 28, 2021 * 19 posts * 111 views General Tech Sniper EFI wiring September 28, 2021 * 40 posts * 316 views ... Read more >>
September 28, 2021 * 7 posts * 77 views
ttocs said: I feel like I am rebonding with it now after the t56 install. I was so comfortable that I knew exactly what speed was what gear and I could tell just by feel what gear its in. ... Read more >>
September 28, 2021 * 4 posts * 90 views
Venompower said: It is, this was an old post before I found the water in the intercooler pipes! Read more >>
September 28, 2021 * 9 posts * 135 views
Knightstallion said: Ok so I'm about to go get my 3rd set of gaskets, what's the trick to getting the bottle seal in, the first time the whole bottom of the timing cover was sticking out by a 1/4 inch, ... Read more >>
Continue reading...
