OldZeuski
- Joined
- Jul 17, 2024
- Messages
- 37
- Reaction score
- 13
I am about to start ordering parts and I have several friends who had to use cowl hoods to fit intake manifolds. Seeing as I just painted the car I was hoping to avoid replacing the hood. Does anyone know if a trick flow track heat intake manifold will fit under the hood, AND fit over heads with taller valve covers for roller rockers?
I'm keeping the stock rail with bigger injectors, but at some point I'm probably getting roller rockers on AFR 165 heads and I'm not sure if the track heat will require a spacer, and therefore run out of clearance with the stock hood, if it isn't already too tall.
Thanks in advance.
Thanks in advance.
