Tomwas
- Joined
- Apr 30, 2020
- Messages
- 55
- Reaction score
- 35
Having my filter and pan gasket replaced, how many quarts are needed to refill after the job... 98 4.6 gt automatic...
It’ll be roughly 6 quarts. Depends on how long it’s been sitting still and how long you drain. I would pick up 8 to be safe. Don’t forget that it takes Mercon V. Don’t use dex/merc, that will lead to problems.Having my filter and pan gasket replaced, how many quarts are needed to refill after the job... 98 4.6 gt automatic...
Are you draining the torque converter at all? IMO I would go ahead and do it while your there. It's around 14 quarts if you drain it all.Having my filter and pan gasket replaced, how many quarts are needed to refill after the job... 98 4.6 gt automatic...
You need a new hydroboost assembly, I would get it fixed asap. It can cause other issues.Having second thoughts now, when doing my brake job I found lots of old ps fluid up in the driver side fender well below that power steering booster jobby.. Thinking this is leaking in some manner and going below the car on to the cat... Wiped it down under the Car today finished see the source.. But it's also got old fluid below the unit on the firewall also... Is this known for leaking at all..??
Not as much as you think. Around $200-250 for a Motorcraft unit. Don't go cheap on this part!On shit, sounds expensive...
I Understand completely. A good shop will charge $150-200 labor w/ warranty.I'm 68 and a shade tree mechanic, don't think I would attempt it myself though..
Definitely monitor it. Be safe brother.She put 30k miles on it in five years... Car was in Jersey, she went to rutgers... The fluids actually preserved everything.. Paints like new in the fender well and under the hood once I wiped it down... I t Just get drips under it when it's parked overnite...
