How should this idle/run prior to tune?
Musclemustang65
Ive heard horror stories about 94/95 computers ant itll be a bit before its tuned so im wondering how it might idle and run until the. Major mods are AFR 185 heads with 1.6 rockers, Edelbrock RPM intake, Comp 274HR cam, and a Bullet MAF calibrated to the 38lb injectors.
95opal
Shes gonna load up and want to stall...a quick blip of the throttle will keep it from stalling. Shell also probably run lean once your in the throttle. I wouldn't plan on cruising it till you get a tune or until you can at least see the AFR.
wbarter
