how to properly lower a mustang
g_dogg
im installing maximum motorsport Camber Caster plates on tuesday.
my car is lowered with KYB agx shocks, and i think eibach springs (they are red but not sure its eibach).
is there anything else i need for my mustang to be properly lowered?
the ford guy told me something about rack bushings?
jpajkos
Look into some Maximum Motorsport Rear lower control arms.
rack bushings?? only if you stock one's are cracked, or if you want a firmer feel.
you will want a bumpsteer if you go over 1.5" or so.
Steeda or MM makes them.
did you get the 4-bolt CC plates? I have those on my car.
I've found the MM is excellent with questions on the phone. you could call them if you want.
Nick
You will only need the rack bushings to offset the rack if you had a tubualr k member. The springs, shocks, struts, and c/c plates are all that you need to "properly" do it.
marktuck99
