How to remove Front Bumper Frame Damper Vibration Balance Weight 1995 Mustang
maillemaker
I have discovered that my Front Bumper Frame Damper Vibration Balance Weight on my 1995 Mustang GT Convertible is broken.
I am trying to remove it, but cannot figure out how to remove the bracket from the front of the car. I have done some googling and found a thread where a guy said he did it without removing the bumper or fender, but I cannot see how.
There is a nut that is easily removed, but there also appears to be a bolt that comes in from the front of the car that I cannot see how to access with the bumper on.
Does anyone know how to remove this?
maillemaker
OK, I figured it out.
You can't take the front bracket out without removing the bumper, I suppose.
But the bracket is U-shaped. You can get a box-end wrench in there and remove the nut on the end of the dampener. The dampener has a molded-in stud on either end, and a nut holds it in place. You can get to that nut. I held up the dampener with a tow strap threaded down through the intake hole in the firewall so it didn't come crashing down on me while I took off the nut.
White Pony
Congratulations on figuring this out. I'm trying to remove my damper to get to the fog light mount and it's got me completely stumped. Your first pic seems to show that it's broken off the the rear mount. Or did you release it from the back mount? Can you be more detailed on your procedure?
dsrtjeeper
ah, ok. I was wondering if I really never saw it or.....
It's supposed to counteract chassis flex. The convertibles came with the x brace also. Things get a little less rigid when the roof is missing.
jrfitz63
