How to separate the tie rod from the spindle?
delling3
Sterling Heights, MI
Anyone got a suggestion for how to get the damn tie-rod end to separate from the spindle? I am in the middle of tearing my front end down. I am replacing my control arms, need to disconnect the spindle. I have the nut off, and I have beat the damn thing with a 2-pound ball peen hammer to no effect.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Penetrating oil, torch, bigger hammer, pitman arm puller to press it out, or any combination of all the tools. Hit the spindle where it goes through to try to loosen it up.
evilcw311
Most Evil Member!
Louisville, KY
How about I hit it with my schlong instead?
I can't take it HAVE YOU EVER SEEN A BODY LIKE THAT IN YOUR LIFE?!
She happens to be my daughter
Oh well I guess you have......
evilcw311
Most Evil Member!
Louisville, KY
Obviously you don’t know the movie it’s from. [emoji38]
Werecow
Virginia
Would you prepared if gravity reversed itself? The only thing I can't figure out is how to keep the change in my pockets. I've got it. Nudity.:p:p
bs.austin.tx
