Best to text me 440-476-4114 all is 94-98 and Cobra big stuff P/U only 96-98 Cobra hood 300.00 96-98 Cobra front bumper cover 300.00 96-98 Cobra B heads with proper COBRA cams 300.00 96-98 COBRA cams 200.00 for all 4 96-98 Cobra intake upper and lower 400.00 96-98 Cobra throttle cable and bracket 150.00 Fidanza 8 bolt Modular flywheel 150.00 10.5" Centerforce clutch 10 spline 100.00 T3650 transmission with Hurst shifter 500.00 IMRC plates with controller 100.00 96-98 Cobra fuel rail 75.00 OEM 4V cast headers 60.00 96-98 T stat housing with all 3 hoses 80.00 96-98 4.6 Cobra oil cooler adaptor 165.00 96-up 2V oil filter adaptor 75.00 96-98 4.6 DOHC timing cover 60.00 96-98 Hydraboos and master cylininder 70.00 no hoses 99- hysdraboost and master cylinder with all 3 lines 200.00 Magnaflow Cat back 98-04 GT 250.00 Aftermarket rear sway bar 70.00 96-98 Cobra High flow Cat X pipe 200.00 96-98 Cobra coolant crossover tuble 50.00 Eibach 1.5" lowering springs 150.00 96-98 clutch pedals with quadrant and adjustable cable 80.00 96-98 4.6 DOHC ECU 150.00 black leather couple seats 300.00 some wear ignition key and cylinder 40.00 black 94-97 console 100.00 black 94-97 passenger airbag 75.00 4.6 iron engine block 100.00 302 5.0 longblock runs fine has a noise 100.00 mach rear speaker box with Pioneer speakers 50.00 black door pulls 30.00 04 GT ecu with Kenne bell chip 100.00 99 GT ecu auto 70.00 lower 5 speed shift boot 25.00 99 PI heads need cleaned up had detonation 150.00 no cams MAch door speakers 35.00 Mach tweeters 30.00 a set T45 clutch forks 30.00 94-04 rear convertible window regulators 30.00 each 94-97 Exhaust hangers set of 4 35.00 tan 94097 consoles 50.00 each 94-04 BLACK convertible top on frame nice shape 300.00 black 96 door panels average shape some flaws 70.00 stock 94-98 GT hood 100.00 Gt front covers with headlight support 100.00 GT rear covers 50.00 GT trunks and wings 80.00 94-95 taillights black 40.00 GT headlights OEM 50.00 parking lamps 20.00 each outside pillar trim 35.00 a side ground effect 40.00 a side 5.0 complete engine harness 150.00 5.0 fan 40.00 5.0 radiator 30.00 power seat track 4 way 125.00 manual tracks 30.00 Black cloth seats CONVERTIBLE some wear 250.00 power seat track 125.00 black dash 125.00 black rear panels 75.00 radio bezel 60.00 Mach 460 parts, I have anything needed... ask..... Mach amps all 3 set 80.00 mach rear deck covers 40.00 Tan convertible rear panels MAch460 80.00 factory 94-98 Cobra front springs 40.00 KYB front struts 50.00 6 speed shifter knob 20.00 94-98 wings 50.00 94-98 COUPE black seatbelts whole set 50.00 windshield washer resivours 30.00 door power window motors OEM ford 25.00 each Convertible power windor motors rear 25.00 steering columns 5 speed cars 40.00 steering shaft 40.00 Flowmaster cat back from a 96 Cobra 200.00 75MM Pro M mass ait 42lb 100.00 8 bolt Cobra flywheels 60.00 4.6 starters 40.00 4.6 Cobra alternators 45.00 Mach 460 CD players 50.00 94-98 tan door pulls 40.00 Ac condensors 50.00 96-98 Cobra fuel lines tank to engine 150.00 93-95 engine mounts will fit any 5.0 35.00 4.6 DOHC cobra spark plug wires 30.00 bins full of small 4.6 Cobra engine parts, AC parts, CCRM fan controllers, wiring, interior parts, wings, switches, door wiring, MAch 460 wiring, emissions tubing, radiators, hoses, used stock clutches, flywheels, just so much... see what I got...... So many more parts just ask..... I have a barnfull of stuff....
