I hate this car. Grouding Issue?
T
Twista
there are 4 connections needed on the relay to be safe. The tabs on the bottom are numbered so you can tell which one goes where. It could be as simple as me telling you to ground pin 85, connect pin 86 to the switches output, and then finally #30 will be your new output to the starter and pin 87 needs to go to a solid 12v wire that could be either an ignition or constant as it would not matter.
Or if you want to go the really easy way I could connect the wires to the relay for you and ship it to you with a color code so when you get it just ground the black wire, connect the white wire to your switches output, the red wire to a 12v constant or ignition and then the green wire would go to your starter. Its not a big deal for me but it could save you a huge problem later.
Sounds good. I'm going to ask a buddy first if he can help me wire up a relay. But if not I'll take you up on the offer.
Thanks man
* Sent from tapatalk while sitting on the toilet at work*
bs.austin.tx
