I need better traction
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Do you have spring isolators installed currently? If not, putting those below and above the spring will raise the car up some. I just recently did this to the rear of mine.
Mr horsepower
If you mean me the engine internals are stock but here’s my list of mods
CAI
75 mm throttle body
Trick flow plenum
UDPs
Long tube headers
Lightened flywheel
Cobra clutch
Tremec 3650 box
Aluminium propshaft
Cobra disc and callipers
4.10 gears
Diablosport 99 Ron tune ( 91 Mon )
Extreme nitto 315/35/17 tyres on rear
I’ve most likely left something out but I think I’ve got all the bolt ins but cams now. just wish I went the supercharger route now from the beginning but that will hopefully be next year now till I get that done.
I assume the Nittos are Dr’s are they?
I ran Nitto 555 275/40/17 on 9” Cobra R’s on our 98 Vortech Cobra making 425 to the tires with 3:73 gears and had little traction issues - only when racing. We switched to 315/35/17 Nitto Dr’s on the same 9” Cobra Rs and had no traction issues at all.
Are you getting wheel hop or just blowing the tires off? Are the clutches in your posi unit in good shape. If you are doing a burnout do you get 2 solid black patches?
BTW Nitto Drs are a harder compound than M/Ts or BFGs and provide less traction.
BTW2 the pic below is our 95 Cobra with 315/35/17 On 10.5” Cobra R Rims. They worked well up to about 650RWHP. Fronts were 255/45/17 on 9” Cobra Rs
Adam Vinnicombe
Adam Vinnicombe
Yes mate I get two solid black lines when I do a burn out and I’m not getting wheel hop
Ccrider
