MeanGrn Gt said:Snakebit said:MeanGrn Gt said:he better be granny shifting it or they will be pullilng out that t5 for a rebuild soon ;D. If i was you paul id get a set of heads and some lca's if you aint hooking
if he isint very good at it then hell yea,........im fairly speedy on the shifts, i always powershift at the track.
powershifting a t5 isnt a good idea. 3rd gear will go bye bye pretty easily. If your decent with the manual tranny you can shift pretty quick without doing a true powershift and not lose much time. I wouldnt dare powershift a stock t5.
the tremec 3550 is same thing as the tko 500 and 600 i believe which means you will need everything for the tranny swap (crossmember, driveshaft, bellhousing etc.). astro performance makes there own stronger version of the t5 called the super t5 i think. It is similar to the g force t5 but it is supposed to be a little better. Id stick that in as its a direct bolt in and no extra costs of swap parts. I was planning on putting one in as my t5 grinds a little but money is to tight to allow me to buy a new tranny so ill pry just rebuild the stock t5 :-[
i found that out the hard way that 3rd doesnt hold up good at the track if you barly use the clutch
