i ran a 13.02 @ 106MPH in the 1/4 im pissed
95KBGT
even with heating up the tires and launching at 3500-4000 RPMs i still spin like shit. IM SO EFFEN CLOSE. So say the bottle is not an option what else can i do to get there. Maybe Conrtol arms for the rear? actual slicks? Moiser 31 spline axles WHAT DO I NEED. Heads? maybe a F303 cam, cause i take off then loose all my mid to high power... :rollinglaugh:
i have vids of all my runs but im too exhausted to up load tonight, i will do it tomm.
scarface
be more specific. What was you times...60ft, etc...
You probably just need to work on hooking up
your MPH is alittle low so maybe that 300rwhp dyno you did is accurate and your car really isn't that fast :-X
Some heads and a blower cam would probably wake your car up a ton....
TRUUBLE
-Never Forget-
You need slicks. If you ain't hookin, you ain't bookin.
TRUUBLE
-Never Forget-
95KBGT said:
60' foot times the best i cut was a 1.8
1.8 isn't really that horrible. You should be able to get into the 12s with that 60.
I'm thinkin the car ain't breathin . . . . you need heads. You should have bought those TFS HighPorts I had . . . bad ASS heads.
MeanGrn Gt
wow you only got a 13 sec pass. I would be dissapointed too. I wouldnt bother with a cam yet but if you do get a custom cam from fti or camshaft innovations. Heads would be a nice addition but why are you not considering meth inj also?
scarface
you def. need heads....those stockers are choking you up bad!
95KBGT
the thing is im a noob when it comes to heads. I was told to get windsor Jr heads or trick flow heads. I just want something i can buy and bolt right up without any additional modifications..any ideas?
yea be sure to get them with 1:90 valves not the 2:xx you dont want any piston to valve contact :(, I would try some AFR or Edelbrock heads. If you want a cam the F is a nice one to run with a blower.......but you cant beat a custom grind.
A flat 13 in the quarter is right at a 8.30 in the eighth.......can you post your time slip. Not bad numbers but there is room for improvement for sure, with 300rwhp I still think you can go faster.
Suspect
ATL
did u let the car cool down? ice it, i know those kbs can get things hot. prolly can get 12s with just letting it cool off.
SvtBlack95
dont feel bad paul i ran a 13.2 but that was on streets with not traction at all and granny shifting.... how many passes did you get at the track?
95KBGT
i did 2 runs then iced it for 45 min then ran 3 more times my scanner is being gay here is the break down
1st Run
r/t: .480
60' 1.940
330 5.554
1/8 8.564
mph 83.16
1000 11.126
1/4 13.257
mph 106.22
2nd run
r/t .339
60' 1.898
330 5.477
1/8 8.402
mph 83.51
1000 10.921
1/4 13.020
mph 107.62
3rd run
r/t .510
60' 1.901
330 5.512
1/8 8.436
mph 84.53
1000 10.959
1/4 13.050
mph 108.12
4th run (missed 2nd)
r/t .221
60' 1.933
330 6.016
1/8 9.037
mph 83.26
1000 11.625
1/4 13.758
mph 106.15
5th run
r/t .213
60' 1.986
330 5.662
1/8 8.610
mph 83.22
1000 11.141
1/4 13.247
mph 107.15
i thought my trap speeds was good enough for 12's im a little worried cause i think my tranny if fixing to go, id shut down and put the shifter in neutral but there was alot of noise when i did. o well, drive it like you stole it.
im thinking before i get into heads, i need to buy some slicks and drag lites for the track and some Control arms for the rear
scarface
suspension would help, there are people with less mods, running better times because of it.
you need some rear end parts like shocks / LCA'S / UCA'S to help plant that ass end, you can cut a little more off your 60ft time to lower your eighth time, and your over all et. Is your car spinning on the 1--2 and the 2-3 shift? Are you powershifting or granny?
MeanGrn Gt
he better be granny shifting it or they will be pullilng out that t5 for a rebuild soon ;D. If i was you paul id get a set of heads and some lca's if you aint hooking
TreeScholar
