atrainsgt said:I've never driven a car that has this hanging idle, I may not like it simply because I've never had it. I hear an aluminum flywheel gets rid of most of the idle hang, for road racing that hanging idle is terrible.
voidfinger said:well with an auto would the low idle cold starts cause problems?
J.R. said:myillwillinc said:what is the benefit of this mod?
If you have an auto, you probably won't notice, but on manual car's when you go to shift, it kinda stays at the same RPM for a second, then slowly drifts down. You could shift 17 times in the time it takes to drop back to idle.
BTW, I'm sure Ford does this to keep people from mis-matching rpms as much as possible and keeping the shock load off the synchro's. NOt that I think it will be an issue or anything, just fyi.
my96gtstang said:Well I know autos have SHITTY throttle responce compared to manuals but hopefully with that stall, jmod and gears it won't be as much of a problem haah.
Also I noticed when reving my car compared to when my friend revs his 94 50 5speed, his revs up then drops right back down... autos rev up then slowly drop back down to idle.... it's kinda annoying, that's what I meant by shitty throttle response...
J.R. said:Nope, but I'm guessing it's a second, third or even fourth hand car?
