Has anybody here relocated their IAC? Trying to start tidying up the engine bay a little and it is hideous sitting on the front of the plenum. Ran across an MRR Relocation kit that they sell with a block off plate. Does anybody have any first hand experience relocating yours?
I have the MMR IAC relocation and block off plate. I plan on doing the install in the next few days, I'll post up pics and how everything turns out.
Okay, so started doing the IAC relocation. I don't know if I'm overthinking this, but I'm just not understanding how this is supposed to go. Below are pictures of before and after with the block off plate installed. I took a picture of the IAC relocation adapter that you get from MMR with the billet bracket and the two fittings. Does anybody know where these get connected to? I'm guessing one side has to have vacuum from the manifold...correct? What about the other side? Just a bit confused with this whole setup and I'm probably over thinking it. Before: Block off plate in place: Hardware for relocation adaptor: Any input or suggestions appreciated! Thanks
Messing around with it a little more. So here is the IAC with hose that is removed from the plenum: Back side of IAC: Does the adapter get mounted to the back side, and only one of the fittings is used to run to a port vacuum side on the manifold?:
All you are doing is routing air around the throttle blade.. that's it. Nothing more. Sent from my SM-G900V using Tapatalk
One hose simply goes between the maf and the tb and the other goes to the plenum. Should be 8 an or 1/2" npt Sent from my SM-G900V using Tapatalk
I run a 6061 plenum and the whole point was to try to move all this junk to the rear of the car so its not visible. Trying to avoid using anything up front of the plenum. Found a port on the #4 runner i think I can make work on the manifold
Be interesting to see what happens trying to put it on an individual runner.. that should cause just that cylinder to run lean as **** at idle. Iac should be plumbed to the back of the 6061 elbow then Sent from my SM-G900V using Tapatalk
I wonder if you could order the upper plenum with the IAC mounts on the rear. It looks like the mount is hand welded in so I bet it could be ordered that way.
I contacted Aaron from 6061 in the past about this and he said that it technically can be done, but something must be eliminated whether it be throttle bracket, IAT location, etc. I run my IAT in the rear due to my meth setup, so its very crowded on the back side the way it is. I may be looking into a vacuum block setup as well
Whats the point of the plastic square box? If all else fails, couldn't you replace it with some black braided hose to match the rest of your engine bay?
Is there anywhere on the edelbrock to mount the IAT? I want to have mine drilled/mounted in my supercharger manifold to read more accurate after the meth. Heres one mounted in the main cavity of the blower. And here is one that was mounted in a runner.
I've read before that the little black box is some sort of resonator and have read mixed reviews of removing it. Bob I'm going to scope out the Edelbrock for potential locations for the IAT. Those are some interesting areas to mount it on those manifolds. I don't know if I would personally mount it on a runner, but I'm sure it works perfectly fine.
I think the SVO blower guys mount it on the runner so they don't have to remove the rotors from inside the blower when they drill and tap for the lightning IAT sensor. I am going to send mine to Steggy for porting so I will have them drill and tap while everything is apart.
