I would want the meth far enough in front of the iat so it is completely atomized by the time it's read. Spraying the stream directly onto the iat isn't going to give you an accurate reading.I wonder how far apart the meth nozzle and the sensor need to be? I remember seeing a flat spot on two of the runners that would be where it would go but also wondered if I just moved it to the back up my upper intake if it would be ok?
That's where mine was until I went to dual nozzles.. the 625 just wasn't enough. 1000 made a hell of a difference thoughI was thinking of putting the meth nozzle in the discharge of the blower snout, mine has a threaded hole
I hear you, maybe come up on the bottom of the intake elbow with a littl port.Mine has a spot to drill/tap and I have considered it but was hoping for a cleaner look and to run it up under everything to be hidden.
That's it, did it not work good there?That's where mine was until I went to dual nozzles.. the 625 just wasn't enough. 1000 made a hell of a difference though
Sent from my SM-G900V using Tapatalk
the dual nozzle kit would have meant he would have added a 2nd nozzle just like the one you already saw so he would either need to drill/tap another hole next too it or find another spot that was close.
Meth doesn't really work well until you get into higher boost levels. I believe Michael Plummer doesn't recommend using it anywhere below 12#s. I'm at 14-15. 625 only dropped iats like 40*. 1000 dropped me up to 125 degrees all the way down to 120 wot on an 85 degree day.My question was mainly directed to the need to upgrade to a second nozzle. If I'm going to do a meth kit, I don't want to dick around with a single nozzle kit if it's highly insufficient. I'm just curious at what power level the need to upgrade is.
Having the iat in the maf isn't doing you any favors when you're using methIf you haven't already bought your maf I'm pretty sure there is some that have the iat built in.
OK, been looking at building my own kit and I'm currently at 14psi.Meth doesn't really work well until you get into higher boost levels. I believe Michael Plummer doesn't recommend using it anywhere below 12#s. I'm at 14-15. 625 only dropped iats like 40*. 1000 dropped me up to 125 degrees all the way down to 120 wot on an 85 degree day.
To make that more clear, I was seeing up to 245 degree iats and the two nozzles brought me down to 125 degreesOK, been looking at building my own kit and I'm currently at 14psi.
