IAT sensor relocation for the Vortech?
Discussion in '94-95 5.0 - Specific' started by gnx547, Jun 29, 2015.
  1. ttocs
    ttocs Legend
    25,762
    2,683
    if I am not mistaken its just a thermistor which is just a fancy word for a thermal-resistor which is just a resistor that changes resistance according to temperature. If that is the case the resistance should be the same with no polarity so it would not matter which way it was wired.
  2. 2slo95fiveoh
    2slo95fiveoh Well-Known Member
    2,559
    Dec 31, 2006
    Lawrence, Kansas
    ^ bingo.
    If I remember right, you have constant 5v going to it, and depending on the air temp varies the resistance, which varies the output voltage directly to the pcm..
  3. busta
    busta New Member
    22
    Dec 5, 2015
    Well in that case crisis averted. It runs great. I just need to get it on the dyno to check AFR's at this point.
  4. ttocs
    ttocs Legend
    25,762
    2,683
  5. BLWNBYU
    BLWNBYU Active Member
    296
    10
    Aug 28, 2006
    Talked to Decipha and I'm just going to wire my ait in to my slot meter. Saves me an extra bung to weld and less wires in the bay :)
    Sent from my SM-G900V using Tapatalk
  6. busta
    busta New Member
    22
    Dec 5, 2015
    So rather than open a new thread since we're already on the discussion, I installed a Vortech V-2 S-Trim on my '94 Cobra and am currently in the process of obtaining the parts to upgrade the fuel system. Stock longblock, AMS Powerpipe not yet installed. I'm intrigued by the idea of a slot style MAF, the PMAS HPX-E in particular. What MAF housing from PMAS would you recommend? I was looking at this one in particular http://www.pmas-maf.com/product/h30/ along with the wiring harness adapter. 80lb injectors along with a TRE Performance 340lph in-tank pump as Decipha recommended in another thread and I was going to have Bob Kurgan do a mail order tune for me.
    Thoughts?
  7. BLWNBYU
    296
    10
    Aug 28, 2006
    On my 95 which is running draw through and a4 inch power Pipe, it was way easier just to use their 95 millimeter 3000 kg an hour meter instead of the slot meter. My second car is blow through which is running 3 inch tubing so the HPX was the obvious choice on that one
  8. BLWNBYU
    296
    10
    Aug 28, 2006
    Ultimately, I would discuss it with the tuner but I would have to say for tune it any day over Kurgan call me especially since they would both be mail order
  9. busta
    busta New Member
    22
    Dec 5, 2015
    I may be misunderstanding your post - do you tune?
  10. BLWNBYU
    296
    10
    Aug 28, 2006
    For Decipha to tune it
  11. busta
    busta New Member
    22
    Dec 5, 2015
    I would completely be open to that as well.
  12. gnx547
    gnx547 Active Member
    459
    Jan 22, 2010
    I was wondering if I washed out the piston rings by not having the IAT plugged in while the car was running? Back then, I had the car running at idle for about 30 mins for a few days but the car wasn't driven. I did drain the oil out and there was gas in the oil and the plugs were a little wet with gas. Are the pistons rings washed out from this happening?
  13. BLWNBYU
    296
    10
    Aug 28, 2006
    Unlikely. It will take alot of gas to do that.
  14. BLWNBYU
    296
    10
    Aug 28, 2006
    Also.. update for this thread... I wired in my iat to the two wires on my hpx. Didn't care what went where. Reads identical to room temp so it works perfectly as is with no tune adjustment or transfer function
