Idle issue, a/c caused
Z06killinsbf
McKinney, TX
I am having an idle issue with my car. During normal running, no a/c on the car runs great, has a slight idle hang between gears but not bad. If I'm driving and I turn the a/c on it's happy. If I have the car off, a/c on and turn the car on it immediately hunts and stalls over and over again until I can get it rolling and it will normally clear itself up. Is this one of the typical idle issues or is my computer/sensor messed up telling the car to up idle with the compressor kicking on?
i will note the PO removed all the smog and EGR parts and it has the stock tune.
i did put a good IAC on I had laying around with no change.
95 GT Cobra intake, 75mm BBK TB, stock cam, Trickflow heads.
I have not performed the "idle fix" trick yet since it only does the surging when stated above.
tykempster
Does your AC work good? Mine was low on refrigerant and the AC clutch would engage and disengage a lot.
A_+
have you tried a base idle reset? i just got my car tuned but have yet to perform a reset because im fukin lazy but the car idles normal until i turn on the ac. Im sure a reset will fix MY problem...
