dsrtjeeper
- Joined
- May 28, 2015
- Messages
- 43
- Reaction score
- 0
Do the '95 GT's have one. I can't seem to find it. Any pictures or diagrams are greatly appreciated.
Thanks!
Thanks!
There are two types of grounding systems. Common ground is were they all come to one wire that that goes to ground and floating where each injector would have its own wire that went to ground. "Floating" doesn't mean that it isn't grounded just that each one would have its own. As I said this is a common ground system. What are you wanting to know or needing to do?
check the wire colors on the injectors and see what color is common and/or just trace them back. I believe the "R" that is next to each ground wire in the pic above refers to the color of red that ford liked to use for grounds back then.
having just taken that harness off and then moved it in my attempt to tuck/hide all the wiring in the engine bay I can tell you that it is not grounded anywhere.
One wire is a ecm ground and the other is a power wire. The ecm switches the ground to fire the injector, so the injectors use the ecm grounds.
