Installing the 5-speed trans
gnx547
I'm about to install the manual trans. I bolted the bell housing first on the back of the engine. Does the clutch cable need to be connected to the fork first before installing the trans??
clutch fork should be connected last. you can't put too much pressure on the pressure plate before the input shaft is through the clutch disc or it'll just drop and you won't be able to get the trans mounted up.
Bub
Pistakee Highlands
When I did mine I installed the fork and put the cable on. Then slid the trans through. Didn't have any issues and everything went smoothly. If your doing this on jackstands I'd recommend putting all 4 corners in the air to keep the car level. I struggled with just the front up.
gnx547
gnx547
I'm having a hard time installing the trans. The input shaft is inside the throw out bearing and I'm wiggling it and pushing it at the same time and it is not going through. Does the trans need a lot of force to get the input shaft in? Any tips on getting the trans in?
gnx547
gnx547
Yes, I used a clutch alignment tool when I installed the clutch.
gnx547
gnx547
I finally got the trans in! What a pain! I got the cross member bolted and how tight should the bolts be? The bolt is all the way through but still turns a little bit. Do I have this tab on the right way?
castine917
wyoming, mi
Tab can go either way. It will go to "frame" either when tightening or when loosening. When you do the opposite it will hit floorpan. So in either direction it will push floorpan some and you need to use caution not to go through. It would have been nicer if ford put a little extra strength at floorpan there.
gnx547
gnx547
When I refill the trans, can I pour the fluid inside the shifter housing?
whiplash473
Northern IL
I wouldn't. What I did is use a 6' clear plastic hose with a funnel up on one end and a stepped plastic piece (I can't remember for my life what it's called) in the trans. Held the funnel above the car and dumped the quarts in. With the clear hose I was able to see when I was full since the fluid starts backing up.
EDIT: The piece I'm trying to refer to us like a stepped drill bit but hollow and plastic. Forgive my lack of brain function.
g36 monkey
Orlando, Fl
I always fill by first pulling the drain plug, pulling the shifter off, dumping new fluid in until it comes out clear. Close the drain plug, open the top plug, fill until it comes out of the top hole, close it up.
gnx547
gnx547
How many quarts does the T5 take? Is it 3 quarts? And does it take Mercon/Dextron III?
I made this fill tube from the cap from a bottle of gear oil. Attached about 2' of 1/4 clear hose. It'll screw right on to the quart bottle of ATF.
Your Haynes manual will tell you whae kind and how much ATF the trans holds but to be sure always double ck at the fill plug.
gnx547
gnx547
Thanks! I'll try that out. On the MGW shifter and it came with some red grease on it..I want to put some new grease. What kind of red grease is this?
Musturd
looks to just be regular grease for your grease gun but even the tubs come with red grease similar to that stuff .
gnx547
gnx547
Where exactly do I pour the trans fluid in the shifter housing? The small hole with the red arrow, or in the shifter block with the black arrows? I poured some in there but doesn't look like its going through.
whiplash473
Northern IL
That's basically what I was trying to explain. Pretty much the same thing I did and it worked great.
BeanMan
