Todd in KS
I saw on a Panther Platform video about the slack in the throttle cable. I found on mine there was quite a bit and I was not quite getting full throttle. I found a piece of tubing that worked but it fell off. Having the tools, I drew one up in 3D cad and had a friend print it. It still leaves a bit of slack as the first tubing I cut raised the pedal too far. I have attached the step files for printing and the native SolidWorks files if you want to modify.
The spacer slips over the cable, you put the "key" piece in the slot and then put a couple small zip ties on. The countersunk end goes toward the throttle bracket.
Just figured out that I cannot post those file types. Let me know if there is some way to get the files out. I did put the PDFs up.
