Got a new regulator, cut down the nipple in half, pulled the blower off, and changed it all out. The regulator is now hooked up to the blower intake (indexed to boost is what I've seen some people call this online.
Found some oil underneath
You can see the regulator on the passenger side fuel rail near the firewall.
Mark where the original regulator was hitting the intake
From what I've found, this Kenne bell system utilizes the stock regulator and at idle the vacuum opens the return line so pressure is reduced. If disconnected, the regulator closes, increases the pressure in the fuel rails, dumps extra fuel past the injectors and causes an overly rich condition at idle. The afr improves with more idle but can go lean on top end since pressure is unregulated.
Now that it's hooked up, at idle it draws a vacuum and reduces the pressure fixing the rich condition at idle. Or so I thought... More into this later... Under boost it closes the fuel return line (regulator) to the tank and increases the fuel rails pressure. This gives you more fuel when you need it at higher rpm.
Remember, all 4 new O2 sensors are installed. After install, the car ran very rich when I used the pedal to keep it running and wouldn't idle AT ALL if I let go of the gas. I suspected the IAC, so I bought a new one but it will not be here until Wednesday. Tonight I dug into this a little more, cleaning the IAC, the MAF and throttle body. It ran smoother but no change to the no idle condition.
I got out of the shower and it hit me. I told the wife, be right back, I think I figured it out .. I had hooked the PCV hose into a boost indexed line on the intake....
I was pressurizing the case and now I know why the vac gauge was fluctuating more than I thought was normal for idle control issue. I was actually boosting the crank case, and the engine couldn't find equilibrium...
Anyway, she is running better than I ever dreamed. Taking my son to school in the a.m. and will report back.
Another note: I found the wide band sensor and will dig into getting it sorted after the Thanksgiving holiday. I still haven't torn down the suspension yet since I was having idling issues but I'm running out of excuses. LOL
The Kenne bell boost a pump is on the short list to look into as well. It may not be needed, but until I figure that out, I won't be doing any high rpm fun or racing until after I confirm afr with some data logging and the gauge. A buddy of mine who is near completion of his coyote swap in a 98 cobra mentioned he already got his tune so he's sharing his contact. The new passenger front seat belt also arrived.
Some fun literature was picked up: 96 Service Manual, 2 magazine from 1995 talking about the 4.6 Cobra release, SVT dealer brochure, 96 Cobra dealer spec sheet, Kenne Bell install manual, Kenne Bell boost a pump manual and diagrams
