Josh's 99 GT
sadlerracing529
Wisconsin
Starting my build thread on my 1999 GT.
A little back story on the car first, I purchased the car at the beginning of 2025. Car is clean and was in general good shape and was tastefully modified when I aquired it. BBK 78mm TB, BBK air intake, Tri-Ax short throw, 4:10 gears, offroad x-pipe to borla stingers, and some BAMA tuning. It has been fun to drive as is but my goal has always been forced induction and more power, even before owning the car.
I live in Wisconsin, so over winter 2025/26 I put it up on wheel cribs and started doing some TLC and upgrades. Changed out the intake manifold as the original had cracked and began leaking, chased and fixed vacuum leaks, fixed some exhaust leaks on the car, changed out all fluids, added a FRPP girdled diff cover, and welded in some Maximum Motorsports subframe connectors. Also swapped out the Tri-Ax for an MGW shifter.
Did a few cosmetic things, Mach 1 grill, moved the factory spoiler back to sit flush with the deck lid etc.
Summer of 2026 Car has been running awesome, pulls hard for what it is, and is genuinely a blast to drive. Subframe connectors really tightened the car up but exposed some wore out steering/suspension components.
Car is about to go back up on wheel cribs for the 2026/27 winter and is getting some serious upgrades.
I ditched the 17's that were on the car and I got a full set of Racestar wheels, running 255/60R15 Mickey Thompson ET Street SS in the rear, and skinnies in the front.
I got a deal I couldn't pass up on a used Procharger P1SC set up so I've committed to getting it installed over this winter.
Most everything is ordered and am waiting for parts to arrive.
Current parts list of what is ordered:
- on3 performance 03/04 baffled cobra tank
- Misc tank vents/seals for new fuel tank
- 03/04 cobra twin pump hat assembly
- 60lb Siemens Deka fuel injectors
- Steeda ev6 to ev1 adapters
- NGK TR6 spark plugs
- McLeod Super Street Pro clutch
- McLeod lightened steel flywheel
- ARP flywheel bolts
Also scored a Trickflow upper plenum and 75MM throttle body, as well as a remanufactured oem throttle body so I will have a few options there to appease whoever does the tuning.
First picture is the day that I got the car, and just a few random progression pics along the way for now, followed by the new wheel tire set up.
Power goals at this set up are 400-420 to the wheels.
Future plans down the road will be building my WAP block that I have fully forged to handle more boost, and id ultimately want a Kenne Bell 2.6 SC and roughly 600 wheel hp.
sadlerracing529
sadlerracing529
Wisconsin
some pics. Will do a better job taking relevant pics now that i have a build thread started.
07GtS197
Fort Myers, Fl
Just a suggestion since I didn’t see it mentioned. Ditch the stock brakes and go with cobra front brakes. The stock v6/gt front calipers suck and are barely adequate for stock power levels. And they’re known to seize randomly.
I used to have an Atlantic blue 00 gt myself. It was a fun car but needed a lot of work. Cool color.
96blak54
Staff member
Lawrenceburg Kentucky
@07GtS197 you are 100percent correct about the brakes! Any added weight to the car reveals the inadequate brakes lack of. That is an excellent suggestion!
With that mentioned, I glanced over on rockauto, they carry stock reman calipers and new painted up caliper. Remans are $100ea and the new painted up come in pairs for $230. Rotors are like $40
sadlerracing529
sadlerracing529
Wisconsin
That is something that is on my list for this winter as well once I start going through the steering/suspension components. I appreciate the tip!
jrfitz63
