Just did the rear brake pads in my 96 gt. After I did it I read somewhere that the dimples on the piston you use to twist the piston back in with have to line up with the nipple on the pads. Is this true? It went together with no problem but I'm just making sure I didn't mess it up. I used the brake tool to press the piston in enough to get it over the new pads. Once that was done I pushed down on the caliper to compress the metal tabs. Then bolted it back to the bracket. Think it's ok?
