BLCKSTNG96
- Joined
- May 8, 2007
- Messages
- 639
- Reaction score
- 2
I have decided to part out at least some of my built 96 gt or at least get out of the mustang game for a little while to focus on other things.,one of the pieces is a kenne bell 2.2 setup.they no longer offer this kit for sale bc the 2.6 has since replaced it.this is not a 2.1 with diff manifold,this is identically the 2.2 from a cobra made to fit a gt from kenne bell.I just had the blower completely freshened and rebuilt and have since put 3500 miles on it.there is nothing wrong with this kit at all and i will list all pieces included and extra pieces for extra charge. Kenne bell 2.2 headunit with lower manifold(port matched) and intercooler The lower manifold has also had the cooling mod done to it,drilled and tapped with correct fittings. Cobra IAC valve Accufab Kenne bell big oval throttlebody BGG GI Joe gripper plate to give no belt slip Reichard racing spotted no slip pulley 2.75 I believe,makes 20 psi Full 8 rib conversion including A/C and oversized crank pulley Custom pvc cold air intake with couplers,tbolt clamps,maf adapter and amsoil blue filter Snyper bazooka 95mm mass air Customized stock fuel rails to work with setup LFP upgraded heat exchanger Intercooler reservoir with pump mounted to it Cobra throttle cable which is need to run this setup All needed heat exchanger hoses Gates serp belt All of the above is like to get $3900 for.this setup on my built motor with ported heads made 554rwhp and 575 ft lbs before running out of fuel at 5500 rpm.this was on a stock tank,rails and lines with a 255 in tank and kb boost a pump.with a duel system the car would easily make 600 wheel.this was at 20psi The extras i have are as follows with the prices Brand new 60lb injectors 3500 miles $275 -$369 new Kenne bell boost a pump 40amp $175 Autometer c2 gauges,electric oil pressure,electric fuel pressure and boost with all wiring harnesses $375 for all with sensors too. Aem wideband with sensor and wiring $145 Gauge cluster pod,no rear deff button $45 Clock pod $45
That's what I can think off the top of my head but im sure i missed somethin plus the entire car is up for partout,motor included,so pm with questions.
