Kennebell 2.1 supercharger
98cobrasvt$
Jeffersonville indiana
So I bought a used 2.1 kennebell that didn't come with hardware. I've tried contacting kb with no luck. Im wondering if the hardware thats stock will work if I just order some from lmr or whatever. Also im stock internals so im going to run low boost probably 6psi with e85 and meth injection. Im not raci g this car or driving on long trips I should be fine right? Thanks for the help..
RAU03MACH
NEW MEXICO
Give me a list of what you have so far i will get the other parts with pictures and numbers
There is a few parts needed
98cobrasvt$
98cobrasvt$
I have blower + manifold i have the belly pan with bolts I have bap an injectors. Thats all I have.. so I need the belly pan to head bolts. The throttle cable on my cobra is a little long already im hoping its gonna work. Someone hooked me up with the instructions so I at least have them.
RAU03MACH
NEW MEXICO
so
throttle cable LOKAR
adjustable pully KB
throttle cable holder bracket LOKAR
belt
the harmonic balancer KB
all gaskets FELPRO
boost pump KB
IRCD MMR remove your intake runners install the delete plates and tune it
iac adaptor KB
KB dose recommend new air filter cold air intake
if you have the rest it should be on the engine
98cobrasvt$
98cobrasvt$
So what about the bolts that go into the head? Someone told me that the Kenne bell belly plate is thinner than the actual Cobra intake. Plinum, so where do I find the bolts at
RAU03MACH
NEW MEXICO
don't believe so it's only going into aluminum
not like a steel block with a lot of torque is applied
98cobrasvt$
98cobrasvt$
I have the bap and 42 # injectors im using ive heard the fmu I shouldn't be using. And yeah your right im just going to try to reuse mine I guess.. and im pretty sure whoever had the car before me did something with the imrc plates cause the wires that go to both are off and it runs fine.
Boostr1
North Jersey
From what I've heard, ever since Kenne Bell has been sold CS is nowhere to be found. People have been waiting up to a year to get their SC orders. KB said they're getting new tooling to manufacture better housings or something like that. I called them and emailed them several times to purchase a new HE (funny story how I got to this point), but they never got back to me. I finally contacted a person thru FB that actually works for KB and they responded but that took awhile as well. I ended up going with a Lightning Force Performance Saleen HE instead.
qzxo_oxzp
