KONI STR T Shocks/Struts Anyone??
Win
Kennesaw, Ga
I have been looking at the STR-T's but have not pulled the trigger. Might be thinking used bilsteins now.
Anyway from what I understand about fox and sn-95 shocks and struts.
The rear shocks are the same except the fox shocks do not come with internal bump stops.
The front struts are longer on a fox than they are on a sn-95. this means when lowering you will gain an inch of travel by using fox struts on a sn-95. BUT!!!!!!!! this also means when your car is lowered your tire will travel and extra inch into the wheel well and rub or rub right through the well cover. Guess what is above the well cover????? your wiring harness! So be careful with fox struts on a sn-95.
so should I get the str-t's???
Bilsteins
i paid 200 or 225 for all 4 of my Bilstein HD's
struts only had 2,000 miles and the shocks had 5,000
SVT CAMR
Chicago suburbs
"Fox/SN", "Fox X 4", "SN95 X 4"??
I went with all sn=95's at all 4 corners. Only lowering it 1". Yes the fox struts would enable me to have that extra inch of travel but I'm just burnt out with modding stuff. When using the fox struts you have be aware of rubbing the well protector because the wiring harness is above it. So I just did not feel like dealing with it.
Mustanger
Southern Oregon
I have been wanting some new Koni Yellows too...I thought they were adjustable by a click setting knob or something...but just heard you have to disconnect the rear shocks, completely compress them then turn the body while holding the shaft...is this correct? Not very doable while on the car looks like...can you guys verify this please?
SVT CAMR
Chicago suburbs
Oh wow you're right. I never knew this about the yellows.
http://www.youtube.com/watch?v=0DmhhcEYsVs
SVT CAMR
Chicago suburbs
I finally was able to get an alignment on my car. Today was the first day out on the road as a street car. Very happy with all the work that was done.
The KONI Str-T shock and struts are great stock replacements for $300. They do their job. Recommended to anybody looking to replace stock dampers. I was on some bumpy roads and the car felt nice like a street car should. The front end did not crash while hitting a bump. I have 525 rate 1" BMR Lowering springs in the front and stock springs in the back with weight jackers lowered about 3/4". I could not be happier. My old set up was set up for straight line and since this transformation it is a whole new car. The KONI Dampers were just a part of the reason. These dampers are not for the racer x types but excellent for a step up stock replacement. That what I come away with after my drive today.
robb15033
robb15033
Northern Va.
Thats great! Best news I've heard all day. I'm siked to get them paired with the H&R's.
99GreenStang
KONI STR-T shocks are awesome have a set on the green stang .
wbarter
