Konig Ampliform 18x9.5 ET25 wheels with 275 / 35 tires
NEW EDG
NoVa
Hard to say, I have Baer 6Ps on all 4 corners but you'd probably have to print their template to double check. What I can is say is if you check the template and it fits pretty much any big brake kit will fit.
NEW EDG
NoVa
The one regret I have was not going 14" from the start. I was originally planning to run them on 17" wheels and when the brakes didn't fit I went to the 18" Apex wheels. I'll be switching to 14" rotors next time I need rotors.
MrBoom
Those look good. Looks like a bigger rotor would fit easily.
NEW EDG
NoVa
The bigger rotor would actually fit easier because there is more space for the big caliper the further you get from the center of the wheel.
MrBoom
These aren't fast cars by today's standard, but i want to brake more easily and make it more fun to drive. Maybe do track days on occasion.
NEW EDG
NoVa
The one thing I will say is my brakes cost damn near what I paid for my car which is another big regret. If I had to do it all over again I would probably do the Cobra R brakes up front and just some good pads and rotors in the rear. But I had to pull the rear end apart to put the Baer e-brake system in so if I wanted to revert back to stock brakes in the rear at this point it would be a ton of work.
MrBoom
I grabbed a set of PowerStop Z26 Street Warrior Brake Rotor and Pad Kit for the front. I'll see how much this helps. Everything on the car was original when I bought it. My Raptor is so much more precise.
MrBoom
Not sure if the pads and rotors were original, but the rotors were seized. Very little wear. Almost new. A lot of rubber mallet to pop them off.
There was a vibration around 60. Seems to have improved. Brakes more consistently and better feel.
MrBoom
Do you just need a caliper bracket spacer to run 14"
happliye
