Launch limiter?
dntgtbit
Who had one on their 94-95? I really want to get one. I know if you run an msd digital 6al you can hook up the msd launch limter for when your clutch is engaged in firsr gear. That's what I want i don't want to have to hold down a button while trying to launch. What do you guys recommend? I already have an msd 6al. Anyway to hook up one to it, or would I need a different style box?
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Addermk2
MSD 2 step ... you just need to be smart about how you wire it.
Sent from my SPH-L710 using Tapatalk
Kboss87
Southeastern, PA
I wired mine to my clutch pedal at first and it was a PITA. The sensor is very sensitive.
I changed it use the ON button for the cruise control on the steering wheel. Whenever I hold in the ON button, 2 step is activated.
Addermk2
You should use a two input circuit. Using both the clutch pedal and another input. 2 step activation would require both inputs, and would deactivate when either was released.
staffamerica74
