Led bulbs in fog light warm white
GTamas
Austria
Do you know of any good replacement LED bulbs that fit the stock 94 GT fog lamps without modifications? Color should be warm white to match the stock halogen headlights.
The ones I can find online are either cold white, or need modifications. I'm also a bit suspicious about the brightness of the bulbs because the last chinese noname led bulb I bought was barely half the brightness of the stock halogenes.
Rod
I prefer Xenon HID kits to LED when it comes to car lighting. You can get the color you are looking for but it requires some wiring to get done. You/I get all kind of people that say "NO! don't put XXX in a halogen len assembly! BAD!". Well to a point that's right, but the trick is getting the bulb adjusted to the correct depth. You have to match where the stock filament sits in the housing with the new light source. Now there are not many LED drop ins the give off good light pattern(lots of dead spots & hot spots) and as you found not many options to light temperature(color), this are my main reasons for liking HID over LED.
clonedropzz
