97_281gt
- Joined
- Mar 6, 2011
- Messages
- 808
- Reaction score
- 0
Will doAlso give him one of your clusters that you think for sure works - see if it works on his car.
Sent From Your Moms Phone
Ahh nothing to be sorry about I'm just glad someone here is helping me out and thanks for the help so far and I'll check the ground at the radio again and seeAh, okay, so your wiring is a little different from the 95 then. Sorry for the confusion - that's why I kept harping on finding a wiring diagram for your year.
So if yours is like mine (just different locations of wires), the ground should be shared between the coolant temp gauge and fuel gauge. However, you said that the fuel gauge now works but the coolant one continues to fail? If so, you might have a dedicated/different ground for the coolant temp gauge.
I'll see if I can find a wiring diagram for your year cluster on the interwebs when I get home from work.
That particular ground (in my year and I think newer, don't know about newer models) is shared by the radio. When people install aftermarket radios and don't wire up the adapter harness properly, they sometimes eff up that ground. Don't know if that's what happened to yours.
And glad to hear the fuel gauge is working, we are half way there!
Yah that does look normal. I assume the black on the crimp caps is from paint or something?
Does the radio work properly? Does it randomly shut off or "restart" sometimes? It's also possible that in your year that ground is not shared between gauges and radio.
The left one wire number 4Edit: Disregard, I was reading that site wrong. I am now confused based on what I see there.
Which wire did you say you tapped into for the Fuel gauge ground? Looking at the pin side of the connectors (not where the wire goes in to the connector): The left side one or the right side one? And then how many wires over from the left side of that connector?
Red with a white line
Ok cool thanks
