What Crank? what rods , I beam or H beam. what pistons what dart block did you go with? Boss blocks are allowed also. Post pics of your cars motor and dyno sheet. If your running a S/T/YSi trim post results. I am truly excited to see how much power my car will make and if you have any good advice on cams to get better gas millage please explain. Keep in mind i know its not about gas millage with a stroker but I got 25mpg with stock 302 and would love to get at least 20mpg. The more info the better and please post your lessons learned on your motor and what you would do different. Thanks
Dart 331, AFR 195 competition heads, ported holley systemax2, 80# dekas, Vortech v1 si w/ 8' crank and 3.0 blower pulley. 100 shot N20, stage 2 meth, no accessories except ALT. Also changing up form draw through to blow through and venting the mondo valve to atmosphere so the location of the valve will be moved from its current spot. No dyno numbers yet as Im not finished with It, if it doesn't hit 700+ I will be very disappointed lol. Run down of the block specs below. Dart SHP Machined Block FordStrokers/RPM 4340 Forged Steel 3.250 Crankshaft - INTERNAL FordStrokers/RPM 4340 Forged Steel H Beam Connecting Rods 5.400 Wiseco 2618 Forged Pistons (14cc, Inline) 4.030 Wiseco GFX Ring Package Clevite 77 H Main Bearings Clevite 77 H Rod Bearings Dart Coated Cam Bearings Screw in Oil Galley Plugs Fel Pro Rear Main Seal ARP Main Studs Freeze Plugs CUSTOMER SUPPLIED CAMSHAFT Cam Bolt Cam Retainer Plate SA Gear Billet Timing Chain w/Torrington Bearing Melling Oil Pump M68 ARP Oil Pump Bolts Moroso Oil Pump Pick up 24519 ARP Billet Oil Pumpshaft Fel Pro 1 Piece Pan Gasket Moroso 7qt Oil Pan - 20511 Oil Return -8 AN Mr. Gasket Oil Pan Bolts Timing Chain Cover - Fox Body Fel Pro Timing Chain Gasket Set No Eccentric Needed
95 GT, 363 dart block, AFR205 72 cc, 9.2 compression, TFS R intake, Mac 1 5/8 ceramic short tube headers, Summit X-pipe, Dynomax cat back, T-56, 3.08 gears, Bullet cam, Tuned with Quarterhorse and then burned to a chip. 350 RWHP Plans to add YSI after fuel and computer upgrades. Picked up Holley HP for computer. Still need to install.
