Lighter and tighter chassis stuff. Lowering back to stock height after a diet & making the chassis feel a little newer.
Snorky
Funny you mentioned the bearing noises being transmitted with the LCAs. My torque arm PHB, Double heim joint LCAs. You feel and hear almost every single bearing roller in the rear axle pinion/carrier/wheel bearings lol. It's crazy! Like a gigantic tuning fork going right to your ass. I always wondered if others noticed that as they modded their rear suspensions.
dsrtjeeper
I can hear the gears meshing in the rear diff when coasting. Gotta love those heim and spherical joints too. They rattle like two skeletons screwing on a tin roof.
But hey, it's a hot rod and a thrill to drive. SFC's are a great mod all in all.
shovel
shovel
I decided to try some rubber in place of the hard center bushings at the axle end, they should be here later this week. If that doesn't cut the noise by half or better I'll have to put the stock set of arms back in - maybe give up a little bit of the tight feel & I'll be fine with that trade for my purposes.
shovel
shovel
picked up some 2"x0.4" rubber discs to fit in place of the hard(er) material center bushings on the BBK control arms.
I bored out the centers with a rasp & installed those on just the axle end of the LCA's. Cut the axle noise down noticeably - still not as quiet as the OE arms.
shovel
shovel
Might as well follow up here - I just got home from a 3 day weekend trip to Cape Flattery (the northwestiest point in the northwest USA, excluding Alaska) - two ferry rides, around a thousand driving miles total and plenty of imperfect roads at every kind of speed.
The rubber bushings in the BBK arms were the right move, we had no harshness from the back of the car and I'm certain I didn't miss the hard center ones. Great ride quality overall with no scrapes, bangs, bottoming out, just no problems at all with the chassis.
I think if I had this car to build over again I might choose not to do urethane engine & transmission mounts, that does contribute just enough vibration to get tiresome after 4+ hours and I know I could just put OE style mounts, but I haven't got annoyed enough to want to actually do it yet.
Also the reproduction Fox Body seats don't offer enough bolstering for how the car actually handles, that was already apparent before the Bilsteins and subframe connectors but those just made it stand out more. Good seats cost real money so that's not a change I can make right now
Lucky57
